June 12, 20178 yr suprise, there is a difference between drive axles. the ones for turbo's are larger by just a little bit on the transaxle end. they look the same but one is just a little bigger. so now i got a driveline that is to big on the tranny end and the store cannot find the records for the exchange. Edited June 12, 20178 yr by damnsubaru
June 13, 20178 yr This is not true on EJ's (the forum you have posted in). It is true on EA's, yes. Turbo are 25 spline and NA are 23. This is well known. GD
June 13, 20178 yr +1 to GD - EJ doesn't matter and EA there's just two spline counts, get the correct one.
