June 19, 20178 yr Hello, The engine is back in the car. BUT, I forgot to line up the converter holes with the holes on the flex plate to install the four bolts. Any ideas would help. Thanks
June 19, 20178 yr Turn the engine with a ratchet till it lines up with the window. Turn the torque converter through the starter hole. GD
June 19, 20178 yr Author Turn the engine with a ratchet till it lines up with the window. Turn the torque converter through the starter hole. GD Thank you.... your awsome
