November 14, 20178 yr Need to need to determine which drivers side cam sprocket goes on 2008 Subaru Impreza RS engine. I have several drivers side cam sprockets and forget which one goes with this engine..
November 14, 20178 yr ebay is a good place for used part pictures sourcing sometimes. i would google search and grease mark the ones you have until you narrow it down. or post pictures of what you got with a number written on each one and we can rule some of them out if not tell you which one you need. get subaru part number from online source and then google search that part number, might show pictures as well.
November 14, 20178 yr If you have the crank sprocket with 36 teeth then the cam sprocket has only 2. Otherwise it will have 7. Check parts.subaru.com GD
