December 6, 20178 yr Hi guys. Buddy got a 2016 crosstrek. He wants to put a lift kit on it. This is the model he wants to put on it. Primitive Racing http://get-primitive.com/lift-kits/148-2013-crosstrek-lift-kit.html he wants me to put it on for him. Im a shade tree mechanic. I dont have a lift or a spring compressor. Anybody here ever tackle this? Recommendations? Is it difficult? I messed with brakes and engine stuff, but never really fooled with suspensions before. Any help is appreciated.
December 6, 20178 yr I kindly suggest you to obtain a Spring compressor, and get used to it, prior to do the removal of the coil springs, because it is very Dangerous to do it wrongly, the rest it pretty easy, like remove and install procedures. Maybe you share here, photos of the Crosstrek, before and after the Lift. in my own humble opinion, a lift less than two inches doesn't worth the effort... Kind Regards.
December 13, 20178 yr i did it myself. just couple hrs but you need spring compressor. they pretty cheap. hope he knows that lift with springs will make car even more harder on road, and kinda worse off road. lift with spacers would be much cheaper and better offroad. Edited December 13, 20178 yr by scalman
December 18, 20178 yr Author i did it myself. just couple hrs but you need spring compressor. they pretty cheap. hope he knows that lift with springs will make car even more harder on road, and kinda worse off road. lift with spacers would be much cheaper and better offroad.. What kit did you use? Not sure I know what you mean about a kit with spacers. I'm fairly certain he wants this for looks mainly, and not much more.
