Hi all I have a 95/2.2 Legacy with 5 speed MT.
The throwout bearing has been whining growling or whatever for a while, I bought the LUK clutch kit and fa lywheel with a new boot too.
I also got a new cable, is there anything else I should have my mechanic check out like linkage or anything Just wondering since I'll likely never again take it apart. :)
Thanks so much.
Dan
Exedy clutch kit - nothing less is acceptable. Resurfacing is fine on the flywheel. You may have quill wear - you can get a trans-quill kit. It uses a Camry throw out bearing. PMD manufacturing.
Buy a new fork and pivot ball from the dealer. Dealer ONLY on the clutch cable as well.
Edited by GeneralDisorder
