February 13, 20188 yr Before I spend the bucks for my engine I thought I would post and get some advise to see if theres a better set up out there. I ran this for two races last year(hopefully picture loads) . Circle track car . It has to be a 2.2 . Homemade intake with 500 holley , escort distributor. Ran great for having 222,000 miles . Its time to build some HP. I would like to twist this to 8500 if need be. I called wiesco and they can make me some flat tops for 150-200.00 each which should get me close to 12:1 . I was going to purchase some rods , either Manley or Eagle I beams . Anything I should watch out for? Maybe a different brand? less cost? Your input would be greatly appriciated before I go spend a chunk of change . Picture didnt load (too big of file) and I dont know how to change it
February 13, 20188 yr Hi, Sounds fun. I'm NOT an engine builder/expert but FYI the stock rods and crank are forged in the '90-'98 (maybe the '99-'01) EJ22e, from what I've read. GL, TD
February 14, 20188 yr Ceramic coated piston's for sure. Back in the mid 90's I ran an early 2.2 ,in a 1980 4wd hatchback . Bone stock other than modified intake 500 cfm holly and I think it was a courier distributor, on a high bank dirt track ... GREAT FUN ... huge black hole for $ .I lost most of the the time running against the 2500 ford 4cly. I could blow by them in the corners "running low" they had to float up to the top. Then down the straightaway they blew by me... I miss it ! Wish our track never shut down.
