The fuel pump relay began a noticeable audible rapid clicking corresponding to the engine cutting out simultaneously, replaced the fuel pump relay,no change, jumped the relay n hot wired the pump still no change, it does somehow occasionally seem to click less after it warms up??? Help... anymore suggestions?
Check wires to relay coil.  I had exact same symptoms about 10 days ago and they were caused by cracked wire leading to the connector.  The copper strands can fatigue crack inside the wire insulation.
It ended up being a bad plug wire arcing out on the manifold..... replaced the coIL an plug wires..... must of shorting an whacking out the electrical fuel system.... thanks for everyone's input ! ! !
And this is why we recommend either OEM or NGK plug wires only.
Store brand wires are crap.
