Code 24 But The IACV Is New, New TPS
I have a 1991 Legacy with code 24 and it would not fire on cylinder one as per the usual in limp mode with said code.
I replaced the tps and now it fires on all 4 and it's a new pre-calibrated IACV. Is it possible calibration is off? All the wires have been rebuilt/replaced that got to the iacv. I put in a new ecu and it runs a tad smoother now at least.
Symptoms:
-Cold engine must be revved to about 1.5 to 2k for a few seconds so it's a tiny bit warm to run decently enough. Warm engine is fine.
-Idle is higher than it usually is.
-Automatic Tranny; Shifts to soon and makes it bog and struggle to speed up
-Overdrive engages and stays engaged until under 40 mph which it never did before.
[Symptoms are the same across both ecu's except the old onw just made the idle a tad rougher.]
Not having much experience with this issue or autos in Subarus I'd be looking for a vacuum leak.
Cheers
Bennie
Sounds like the new TPS needs to be adjusted.
Cold running issue could also be coolant temp sensor. Doesn't always throw a code.
I had it in a shop for the tps. They calibrated it for me.
Thermometer and coolant temp are all working properly. And were recently replaced since they're a common problem for the car in the first place.
Update, I was thinking of something else. I haven't done anything to the CTS.
I've also heard the VSS can be a problem causer for this?
