WANT..good centre diff EA82
I need to resolve an issue ...
Don't we all...
The joys of messing around with old parts, not to mention rare ones.
No way of repairing the centre diff, shims etc?  This is something I've looked into but have not acted upon as I don't need to atm.
All the best.
Cheers
Bennie
Half roller bearings inside ripped into both hardened surfaces and cannot separate the rest of it as it looks so shagged
How different is the EJ centre diff?
Why not upgrade and add an EJ rear housing and you gain the viscous LSD centre
Pinion shaft is shorter for starters. There's no locking mechanism either. Rear housing would need to move with the centre diff of choice as does the matching pinion shaft.
I'm sure the centre diff cases are very different so no swaps possible there either.
Then shifter, tail shaft and gearbox crossmember mods are needed - but I reckon mods for the ea82 setup would be needed in a brumby anyway, just done differently to fitting the EJ AWD rear housing.
Cheers
Bennie
