Zoltan Posted October 4, 2018 Share Posted October 4, 2018 I have a 2001 Legacy EJ25 automatic with low speed hesitation problems. Car is new to me and has 130 000 miles on it. It does look like it was in a bit of a fender bender and had a front fender replaced. I looked underneath the car and it does not look major. Car was giving codes for 3 missfiring cylinders. I changed igintion coil, new NGK plugs and wires. Codes are now gone. Its better, but hesiitation at low speeds is still there, sometimes it will make a poping noise once or twice (backfire I think). It was cold this morning (40) and she stalled out for the first time, so the cold does seem to make it worse. I have searched a around and some say to change the front O2 sensor even though no codes and some say to check grounds. I am checking the grounds but I just want to know if anyone else has any additional experience or thoughts on this? If someone can tell me which grounds to check that would also be a help. Electrical work is not my strong point but I guess I will learn! Thank you for your time , it is much appreciated. I Quote Link to comment Share on other sites More sharing options...
montana tom Posted October 5, 2018 Share Posted October 5, 2018 vacuum leak or the timing off a tooth, both come to mind. 1 Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted October 5, 2018 Share Posted October 5, 2018 yep - def check timing. I wouldn't rule-out a 'dropped' valve guide or burned valve. Quote Link to comment Share on other sites More sharing options...
montana tom Posted October 5, 2018 Share Posted October 5, 2018 Burned valve and it would be shaking at idle , most likely show a misfire code. Compression test would show that. So far in over 30 years messing with subarus and I personally have not seen a dropped guide, even when I was dirt circle track racing and seriously over reving at times, the heads always held together... more than I can say for a few pistons though . 1 Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted October 5, 2018 Share Posted October 5, 2018 there's at least 1 video showing dropped guides. I think a car has to have been quite neglected to have that happen though. 1 Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted October 5, 2018 Share Posted October 5, 2018 (edited) re-read the post, the backfiring kinda points to some timing or maybe valve issue - I suppose over-fueling might be an issue too but???? find the tooth count for the engine on-line. Bring the marks on the pulleys around to the timing points and do a tooth count. here's some wild ideas; one thing that will kill power often with no code is a bad knock sensor, easy cheap to replace too. although it seems to be a rare failure, the car has 2 temp sensors, the gauge part can be good, but the ECU uses a different sensor (in a single unit on some cars) to determine if a 'choke' condition is required and if bad, might not be supplying enough fuel when cold? or too much when warm? another easy thing that will mess with idling - the IACV tube under the intake tubing could be cracked/loose. dirty throttle body might cause idling problems. Edited October 5, 2018 by 1 Lucky Texan Quote Link to comment Share on other sites More sharing options...
Zoltan Posted October 5, 2018 Author Share Posted October 5, 2018 Thanks for everyones input. I will check for a vacum leak. I do have a question about the timing? Why would it run better in warmer outside air temp than in the cold. Would I be correct to assume that this point more to a sensor problem. Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted October 5, 2018 Share Posted October 5, 2018 (edited) some cars with bad plug wires or coil, or, maybe with oil leaking onto the plug boots, will drive-off moisture when temps increase, reducing misfires. Some folks have even used plant mister bottles undehood at night on their idling car - the mist will show arcing and maybe cause engine stumbling. The other issue could be as I oultined above about the engine temp sensor - if the ECU thinks the car is always at a higher temp, it won't 'choke' by sending more fuel to the injectors when cold. plenty of other things other things; like a gummy deposit in the throttle body or gummy buildup in the IACV or ???? might be different viscosities at higher temps. Metal parts change shape with temp, wires/connectors/ground connections could change a little with temp. I have read of older crank position sensors that failed at high temp......who knows? Edited October 5, 2018 by 1 Lucky Texan Quote Link to comment Share on other sites More sharing options...
Zoltan Posted October 5, 2018 Author Share Posted October 5, 2018 Ok. I check my plug boots for oil, and check throttle body and IACV. I will report back tommor ow. Thanks again for your help! Quote Link to comment Share on other sites More sharing options...
Zoltan Posted October 6, 2018 Author Share Posted October 6, 2018 I checked for oil in all 4 spark plug holes. None. I changed IACV, did not help. I changed throttle postition sensor. Nothing. I am sure glad pick n pull is a mile from my house. lol Ok I guess I will order a new front O2 sensor from rock auto. I was told this may be the problem. I am in Canada and the shiiping will take 10 days. I will report back! Thanks again for everyones help Quote Link to comment Share on other sites More sharing options...
montana tom Posted October 7, 2018 Share Posted October 7, 2018 Did you change the engine temperature control? Located on water jacket under intake manifold on pass side. (pick and pull) Knock sensor ? driver side under intake manifold ?(pick and pull) Did you check timing ? Have you done a compression test ? Have the valves ever been adjusted ? Quote Link to comment Share on other sites More sharing options...
Zoltan Posted October 18, 2018 Author Share Posted October 18, 2018 It was the front 02 sensor! Thanks for everyone's time and input! Quote Link to comment Share on other sites More sharing options...
