March 1, 20197 yr Too good to not share! Looked all over the forums and could not find where to buy a ring nut tool or easily make one. The tool straight out of oreilly's : Part number is W1271, probably sold at most oreilly's : All you have to do is cut two of the tabs off like so : Now you have a ring nut tool you can use with an impact! There are 4 notches in the ring nut. Put the two prongs from the tool into the two smaller notches. I was a bit scared that the two tabs would shear off. But after hitting it 3 minutes straight with an impact it held up fine. Sure beats using a chisel and a BFH to knock the ring nut out! Best part is that it was only $20 from my local oreilly's. Edited October 17, 20196 yr by alexbuoy
March 1, 20197 yr I made my own tool and it utilises all four slots in that nut device. I use a large adjustable shifter on it without any issues. Thereare pics of it floating around the interwebs. Too hard basket to find one on my phone atm. Cheers Bennie
March 1, 20197 yr Likewise, I made my own tool for the job. All tool steel, 2 pieces welded together. Big wrench handle to apply a BFH to when needed. Edited March 1, 20197 yr by czny
March 1, 20197 yr And here's some dodgy photos of the tool I made, looks rough but certainly gets the job done: Cheers Bennie
