gritle Posted August 17, 2019 Share Posted August 17, 2019 So a neighbor disconnected my horn a year or so ago because it was triggered and had been going off for an hour or more. He was able to do it easily by crawling under the car but we can't figure out how to plug it back in. We can't even find the horn. I drive a 2005 outback. I think it is a limited edition if that helps. Can anybody give me some tips on where to find the horn and if it should be easy to reconnect. Please. thank you, Quote Link to comment Share on other sites More sharing options...
Suzam Posted August 18, 2019 Share Posted August 18, 2019 It's been a while but as I recall, the 2005 horns are mounted in front of the radiator behind the lower part of the front grill just above the bumper. The wires originally we secured to a point near them, so unless someone pullled or cut them off they should be nearby. Quote Link to comment Share on other sites More sharing options...
gritle Posted August 18, 2019 Author Share Posted August 18, 2019 thanks Quote Link to comment Share on other sites More sharing options...
3Pin Posted August 20, 2019 Share Posted August 20, 2019 hit a parts yard and see what you are missing and grab it. Quote Link to comment Share on other sites More sharing options...
gritle Posted August 20, 2019 Author Share Posted August 20, 2019 I got it reonnected so that the horn chimes when I lock the door yet the horn itself doesn't sound when I press the steering wheel. Any suggestions on that? Thank you, Craig Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted August 20, 2019 Share Posted August 20, 2019 possible clock spring/roll connector problem? try holding the horn down and turning the steering wheel - maybe it's intermittent and you'll hear a chirp - that would cinch it. Quote Link to comment Share on other sites More sharing options...
