Timing belt tensioner interchangeable?
I just picked up a 2002 forester with super low miles 45k and before I put it on the road I was going to change the timing belt, pulleys,water pump etc.. Well before I could change everything, I drove it around the block after I worked on the brakes and the engine started making a terrible noise. Sounded like it was coming out of the timing cover sure enough after getting it apart, started up without the cover on and it was the tensioner making the noise.
My question is can I use one of the older style tensioners on the newer engine? I have a new tensioner and tensioner pulley with the bracket that was for my 96 impreza. Can I switch the bracket and use the older style? Thanks in advance
Yes.  If you swap the entire bracket, roller with eccentric hub, and long style tensioner cylinder it works.
Thanks for the info. I didn't want to put out any more cash if I have something that will work. Its a new Subaru tensioner was hoping it would work. Thanks
