April 9, 20205 yr So I had the 84 Brat at a friends house In his shop so I could paint it. Anyhoo I was letting it warm up Before I drove it home, after about 20 min or so the car just cut off. No stuttering or odd noise it just stopped. It has fuel. I even drained the tank and refilled it. What I don’t have is spark. I have checked and replaced the coil but that doesn’t help. (It has power). Replaced the wires the cap and rotor. The ECM is telling me that I don’t have ignition pulse. My distributor has the four wire type of pickup which I can’t seem to find anywhere. Can I replace this with a two wire set up? Or am I missing something? This was my grandfather’s car which was purchased new in 84. He can’t drive now so he gave it to my daughter. I just spent seven months rebuilding the thing, fixing 35 years of rust and some bad body work from a rear end hit and of course new paint. Thanks everyone.
April 9, 20205 yr Theoretically....gosh that looks like a tidy ute.... A two pin module could work if hooked up to the correct two wires I looked at doing this for emergency spark but stumbled on version 3 of the adaptor block I was making The mounting holes of the four pin and two pin are not the same Just had a change of plan for V4 just then... A two pin may just work roughly bunged in rather than cleanly mounted Two pin will not give knock control but should allow spark to drive it
April 9, 20205 yr Maybe check integrity of the four pins and corresponding females. Squeeze females a little for tighter contact on the module pins Make a new post with module wanted EA81T as title
April 9, 20205 yr Your KCM most likely mounted between glovebox and body. They are in next to turbo model, EA82T and first series from 85 and following year share similar if not same four pin module Must be heaps of unused, unloved S1 EA82T distributors just sitting in the US. I made a wanted call but nothing much came to fruition
April 9, 20205 yr EA82T S1 are mounted on copper heatsink spacers When new modules were available aftermarket, to hey we're claimed to be more heat protected Been tossing whether to add more copper heatsinks to the underside
April 11, 20205 yr Author This car has the EA81T engine. Does anyone have a part number for the four wire ignition module? i have triple checked all the relays coils wires ect. I have correct proper power to the coil but just can’t get a spark and the ECM tells me I have no ignition pulse.
April 11, 20205 yr On 4/9/2020 at 12:11 AM, Johnsomething said: My distributor has the four wire type of pickup which I can’t seem to find anywhere. Does it look like one of these? I don't think I would go for the cheap one. Standard products usually work good. https://www.rockauto.com/en/catalog/subaru,1984,standard,1.6l+h4,1270325,ignition,ignition+control+module+(icm),7172 https://www.partsgeek.com/catalog/1984/subaru/dl/engine_electrical/ignition_control_unit.html
April 11, 20205 yr 2 hours ago, Johnsomething said: This car has the EA81T engine. Does anyone have a part number for the four wire ignition module? i have triple checked all the relays coils wires ect. I have correct proper power to the coil but just can’t get a spark and the ECM tells me I have no ignition pulse. 491468711 They have been NLA for a while.
April 11, 20205 yr Except for here https://www.rockauto.com/en/moreinfo.php?pk=28389&cc=1267736&jsn=348
April 12, 20205 yr Man, been through this with a few suppliers in the US by power of internet. Must be a hoard of them waiting to be found in an old parts bin owned by a guy yet to discover, or care about the interweb. If you get a reco one, likely to have original module not new
April 13, 20205 yr I am parting out an EA81T car that I did see running before I started stripping it (too rusty to save). I can pull this part and sell if you are interested.
