LosDiosDeVerde86 Posted July 7, 2004 Share Posted July 7, 2004 So, i was bored at work today and decided to see what the biggest tire size is that will fit on my 96 legacy. Stock is 196/60R15 (LS model) and the biggest i could get to, without a lift or rubbing on anything, is 215/70R15!!! Quite a difference, and boy did it look odd. I'm wondering how it would drive with that big of tires on...:-\ Quote Link to comment Share on other sites More sharing options...
MorganM Posted July 7, 2004 Share Posted July 7, 2004 Hey not bad! Thats going from 24.2" tall to 26.9". A noticible difference for sure in stance and clearance. If you went any taller what was it rubbing on; strut seats? How much offset would be needed to step away from the strut and go taller? Quote Link to comment Share on other sites More sharing options...
LosDiosDeVerde86 Posted July 7, 2004 Author Share Posted July 7, 2004 Hey not bad! Thats going from 24.2" tall to 26.9". A noticible difference for sure in stance and clearance. If you went any taller what was it rubbing on; strut seats? How much offset would be needed to step away from the strut and go taller?The frame when turning i believe... i had a little more room before it hit the struts Quote Link to comment Share on other sites More sharing options...
MorganM Posted July 7, 2004 Share Posted July 7, 2004 so up front when you turned it was hitting the unibody? Was it just part of the fender? Wheel well ? How far could you turn; as in was it just limiting the overal turning radias or severly inhibiting steering? Was it rubbing where you could just cut/beat stuff out of the way (if one was brave enough ) Quote Link to comment Share on other sites More sharing options...
LosDiosDeVerde86 Posted July 7, 2004 Author Share Posted July 7, 2004 so up front when you turned it was hitting the unibody? Was it just part of the fender? Wheel well ? How far could you turn; as in was it just limiting the overal turning radias or severly inhibiting steering? Was it rubbing where you could just cut/beat stuff out of the way (if one was brave enough ) the unibody, it would hit only when turning the wheel to the farthest limit, so i guessi it would be possible to go up to a 215/75, but i wouldn't want to. Quote Link to comment Share on other sites More sharing options...
MorganM Posted July 7, 2004 Share Posted July 7, 2004 Bump it up! 215/75! GO GO GO That would be 27.7" tall. Now your talking light truck all terrain size Quote Link to comment Share on other sites More sharing options...
LosDiosDeVerde86 Posted July 7, 2004 Author Share Posted July 7, 2004 Bump it up! 215/75! GO GO GO That would be 27.7" tall. Now your talking light truck all terrain size i would like to but i'm worried about killing my engine, transmission, and power steering pump with the huger tires. Quote Link to comment Share on other sites More sharing options...
kevinsUBARU Posted July 7, 2004 Share Posted July 7, 2004 I ran 205-70-15 on my Impreza sedan for like a week, but they were rubbing on the fender liner in front so I downsized to a normal tire. It sure was badass though... Quote Link to comment Share on other sites More sharing options...
frag Posted July 7, 2004 Share Posted July 7, 2004 A car's suspension is, I believe, a very delicate and precise system in equilibrium. I would'nt mess with any part of it without expert knowledge of what else would need to be changed to keep everything in balance. Just my non expert opinion. Quote Link to comment Share on other sites More sharing options...
paladin_w Posted July 9, 2004 Share Posted July 9, 2004 Changing the height would mess with your speedo too, would go further per revolution, but I would love to get em bigger. I wonder if it would completely screw things up putting larger tires in the rear and smaller in front on awd systems, it sure would make the wagons look mean though. Quote Link to comment Share on other sites More sharing options...
Hocrest Posted July 9, 2004 Share Posted July 9, 2004 I wonder if it would completely screw things up putting larger tires in the rear and smaller in front on awd systems, it sure would make the wagons look mean though. no... that wouldn't be a good thing Quote Link to comment Share on other sites More sharing options...
LosDiosDeVerde86 Posted July 9, 2004 Author Share Posted July 9, 2004 Changing the height would mess with your speedo too, would go further per revolution, but I would love to get em bigger. I wonder if it would completely screw things up putting larger tires in the rear and smaller in front on awd systems, it sure would make the wagons look mean though. i'm not woried about the speedo, but i bet putting 2 different sizes on would screw things up royally Quote Link to comment Share on other sites More sharing options...
