Idles fine but dies when I give it gas
Hi I'm new here and I have a 1982 Subaru brat with a 1bl hitachi Carter-weber carburetor it idles great when could and when it's hot but as soon as I give it gas it dies I've sprad every vacuum line I can find with carb cleaner and no leaks if anyone has any idea what it could be that would be greatly appreciated
Try extremely slowly opening the throttle.   To check if the accelerator pump is working.   You can do this in neutral,  parked.  The accelerator pump squirts gas down the throat whenever the gas pedal is pressed.  Usually it can be seen if you look down to the throttle plate, and open the throttle.
It does spray but not much ive rebuilt the carburetor and if I take the top of the carb off and plug the top of the jet with my finger it works perfectly but when the carburetor is fully assembled it doesn't fully spray fuel the accelerator pump is new so I'm at a loss
Is this a sudden new problem, or has it been getting progressively worse ?
Have you checked the fuel filter(s) ?
Checked for fuel line restrictions ?
Possibly the check valve for the accelerator pump is stuck or missing?
