July 24, 20214 yr I bought my 97 impreza outback sport to beat around in ,haul my yacks, and drive back and fourth to work. With in a couple weeks i was very impressed with the old ride. 29 mpg, and it had very well kept Currently I've replaced the factory horn with a set of hella horns, and putt a set of J racks atop of it to haul my kayaks. Thinking of a suspension lift ,and some supplemental lighting as well, we'll see, but as of right now i love my subaru.
July 24, 20214 yr take care of your cooling system, tires, and timing belt system and you should be good for a long time!
July 24, 20214 yr Author the previous owner had timing gears/belt redone at 156,890 , water pump thermostat, at 158,190 (all records from dealership came with the car), the car has 188790 on it now, I serviced it when i got it, checked all fluids, and tuned it up, i'm thinking its good for another 100,000
July 27, 20214 yr I wish you all the best with the modification of this car. You can check 4WheelOnline for other accessories which you can install in this vehicle. Keep us posted on the progress. Edited July 28, 20214 yr by 1990carenthu
