idles high than stalls + engine code 92 loyale
        I have a 92 loyale wagon. Bought it recently figuring out its quirks.  Sometimes when starting It idles very low and stalls. Have to feather the gas for a bit. Other times it idles at about 2200rpm and thenbogs down and stalls quickly.     During this time engine light comes on. I have tried to figure out how to read the codes but can't find very clear information
                              Figures out codes. Anyone know which of these could be the liely culprit    11, 14, 21, 23, 24
Check the CTS.  Coolant temperature sensor.  I have posted other threads with details on this sensor.  It can fail in ways that cause what you describe, and it may or may not trigger the ECU to set a code.
those codes are from different sensors so, possibly something like a bad/corroded ground connection, maybe some rodent damaged wiring???
1988 and later models with Multi-Point Fuel Injection (including Legacy)
11 Crank angle sensor or circuit
12 Starter switch or circuit
13 Cam position sensor or circuit (TDC sensor on Justy)
14 Fuel injector no. 1 (Legacy, Impreza, Justy, SVX); Fuel injector 1 and 2 (XT, Loyale, GL, DL)
15 Fuel injector no. 2 (Legacy, Impreza, Justy, SVX); Fuel injector 3 and 4 (Loyale, GL, DL); Fuel injector 5 and 6 (XT6)
16 Fuel injector no. 3 (Legacy, Impreza, Justy, SVX); Fuel injector 3 and 4 (XT)
17 Fuel injector no. 4 (Legacy, Impreza, SVX); Fuel injector 1 and 2 (XT6)
18 Fuel injector no. 5 (SVX)
19 Fuel injector no. 6 (SVX)
21 Coolant temperature sensor or circuit
22 Knock sensor or circuit (right side on SVX)
23 Air flow meter or circuit (exc. Justy); Pressure sensor (Justy)
24 Air control valve or circuit (exc. Justy); Idle speed control solenoid valve (Justy)
25 Fuel Injector 3 and 4 (XT6)
26 Air temperature sensor (Justy)
28 Knock sensor no. 2 (SVX, left side)
29 Crank angle sensor (SVX, no. 2)
31 Throttle position sensor or circuit
32 Oxygen sensor or circuit (no. 1, right side on SVX)
33 Vehicle speed sensor (VSS) or circuit
34 EGR solenoid valve
35 Canister purge solenoid or circuit
36 Air suction solenoid valve (Impreza); Igniter circuit (Justy)
37 Oxygen sensor (no. 2, left side , SVX)
38 Engine torque control (SVX)
41 Air/fuel adaptive control
42 Idle switch or circuit
43 Throttle switch (Justy)
44 Wastegate duty solenoid (turbo)
45 Pressure duty solenoid (turbo)/atmospheric pressure sensor circuit (non-turbo)
49 Airflow sensor
51 Neutral switch (manual transmission)/inhibitor switch (automatic transmission)
52 Parking brake switch (exc. Justy)/Clutch switch (Justy)
55 EGR temperature sensor
56 EGR system
61 Parking brake switch (Loyale)/Fuel tank pressure control solenoid valve (Impreza)
62 Fuel temperature sensor (Impreza)/Electric load signal (Justy)
63 Fuel tank pressure sensor (Impreza)/Blower fan switch (Justy)
65 Vacuum pressure sensor
