Clutch won't engage.
I once poured 1 and 1/2 quarts of oil on the ground changing oil on my dad's truck. Jumped under there and put the plug back in, went to the house, "dad, we're gonna need more oil! mom, can you get oil outta this shirt!"
  • Replies 56
  • Views 6k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • I'm calling it quits for the night. All I have to do is hook the exhaust back up and put some water in the radiator. I'll post tomorrow after work.
  • I had to work yesterday so i couldn't finish the job. I got it all back together just now and the clutch works now. I'm not sure what the problem was with the new kit/resurfaced flywheel, but it's wor
  • Did you inspect the clutch fork for cracks or deformities? Was the clutch an aftermarket kit that included the throw out bearing? I’ve found aftermarket throw out bearings are undersized - only b
I had to work yesterday so i couldn't finish the job. I got it all back together just now and the clutch works now. I'm not sure what the problem was with the new kit/resurfaced flywheel, but it's working proper now with all the old stuff back in it.
I still need to figure out how to calibrate the throttle position sensor (it's not the stock one) but other than that she runs and drives fine.
after three pages ...about time you sorted it :) another case of 2+2 = 5 my mechanic mate quotes.
So, well done, for not giving up
  As to non stock TPS, what did you fit in place of the stock one ?
It's the same unit, it just has a pigtail attached to it. I had to hardwire it in to the harness.
I have a link to it in one of my previous posts. I'm not 100% sure it's under this user name or espey_16.
