EA81T Head Gasket recommendations?
oczuk32
So my 84 wagon turbo is foaming up the radiator and running hotter. I'm 80 percent that its head gaskets compression leaking into the cooling system. What is the best head gasket that has been used with good results? I've seen MLs (MULTI LAYER STEEL) head gaskets for newer subaru's but not for the old gens. Or should I just go with the Felpro permatorque head gasket?
  • 3 weeks later...
