October 22, 20232 yr Author 7 minutes ago, brus brother said: https://www.smogtips.com/smog-question/4333/Can-My-Car-Pass-a-Smog-Test-If-Monitors-Are-Not-Ready#:~:text=Gasoline Vehicles%3A&text=- 2000 and newer model year,cause a smog check failure. the above link isn't clearly dated but says 2000+ can pass smog with evap not ready! Thanks for the link! I'm fairly positive Delaware says all monitors have to be ready, but at least I can try! https://www.dmv.de.gov/VehicleServices/faqs/index.shtml?dc=ve_faqs_obdi#:~:text=A%3A On-Board Diagnostic systems,repair technicians and our environment. but then I see this from reddit r/Delaware/comments/xcwymw/delaware_dmv_question_readiness_monitors/ Edited October 22, 20232 yr by phyregold
October 24, 20232 yr On 10/23/2023 at 9:26 AM, phyregold said: I'm through inspection!!!!! Let's see about the evap What was the final work/results that got it to pass? Did you leave the spacer or take it out?
October 25, 20232 yr Author 7 hours ago, idosubaru said: What was the final work/results that got it to pass? Did you leave the spacer or take it out? I left the spacer in, I also did about 160 miles at 80mph. The spacer I was using (a generic from Autozone) never seemed to get enough airflow to become ready. I drove for 3 weeks and even did the whole 55mph slow to 10 thing which worked 100% of the time without the spacer. So I left the spacer on, but i really had to go a long distance at a higher speed for it to come ready.
October 25, 20232 yr Did Evap eventually become ready? Hopefully all stays good and it's not just coincidence. It's like the outcome of a rain dance. Sometimes you get lucky and rain is in the clouds, other times you can dance all you want and come up dry. Edited October 25, 20232 yr by brus brother
October 25, 20232 yr Author 10 hours ago, brus brother said: Did Evap eventually become ready? Hopefully all stays good and it's not just coincidence. It's like the outcome of a rain dance. Sometimes you get lucky and rain is in the clouds, other times you can dance all you want and come up dry. Evap still not ready
October 25, 20232 yr 5 hours ago, phyregold said: Evap still not ready Interesting, it passed without the evap monitors being ready? About to head home if I think of it before my kids distract me I'll get a picture of the ones I've used.
