1986 gl inner control arm / ball joint bushing part number
hey! trying to find a part that fits - the part number listed #621108170 as the OEM part doesn’t fit, neither does the aftermarket part. pretty sure they’re the original control arms based on the parking brake line fit. thoughts? help?
  • 2 weeks later...
G’day Groucho,
Can’t help with that OEM number/item. Did you remove the old bushes’ outer steel casing?
A mate of mine recommended this site for suspension components:
https://drwbushings.myshopify.com
They should have what you need.
Cheers
Bennie
EA81 or EA82? FWD? 4WD?
I can certainly help. I work in a dealership parts department, and I have paper catalogs back to the '70s at home. Give me some information
I would’ve thought EA82 at least since the title says 1986 GL.
In saying that I was confused as to what part he was looking for until I searched that part number that gave a better description.
Now we wait for a reply I guess.
Cheers
Bennie
Cheers
Bennie
EA81 Hatches and Brats were still sold here in the US through 87, both with GL and DL trim levels. That's a common problem when getting parts for 85-87 models in the US, as many listings are not clear about which chassis is which.
We reference the EA81/EA82 to differentiate the models - mainly between the brumby parts and the EA82 stuff, somehow they still manage to get them mixed up without the engine reference… we typically don’t reference the DL/GL spec as that’s usually a trim level thing mainly.
Cheers
Bennie
  • 2 weeks later...
24mm was the diameter for EA81 lower control arm bush unless the original bush set-up's outer mild steel sleeve has been remove. Then it becomes a 28mm bush you need. EA82 is the 28mm bush. Get in touch with Doug at the DRW bush address supplied above and he will help - he started of his bush design and production for the Subaru community so knows his stuff.
