vodoobrat Posted August 10, 2004 Share Posted August 10, 2004 Here's my problem. I have a 83 brat 4x4 with 3 spd auto tranny. It wants to stay in 2nd and not wanting to shift into drive. But when the car warms up or is driven a little bit. The shifting problem goes away. What is my problem? Do I need to rebuild it or just change filter in tranny? Any help would be greats. Maybe a vacum line Vic Quote Link to comment Share on other sites More sharing options...
Turbone Posted August 10, 2004 Share Posted August 10, 2004 Its most likely the Governor. Its on the right side (passenger) of the tranny and looks like a big cup. Remove the 3 bolts and pull out the gear. Cleaning sometimes works, but most times a replacement will have to be made. Go to your local wrecking yard and look for any Soob from 82-92 that has a 3spd AT in it. They should work, altho I would try and get one from a later model. Quote Link to comment Share on other sites More sharing options...
vodoobrat Posted August 11, 2004 Author Share Posted August 11, 2004 Thanks...I will look into it Its most likely the Governor. Its on the right side (passenger) of the tranny and looks like a big cup. Remove the 3 bolts and pull out the gear. Cleaning sometimes works, but most times a replacement will have to be made. Go to your local wrecking yard and look for any Soob from 82-92 that has a 3spd AT in it. They should work, altho I would try and get one from a later model. Quote Link to comment Share on other sites More sharing options...
78TurboBrat Posted August 11, 2004 Share Posted August 11, 2004 i have a dead 3at with a bad front and rear diff, but the trans itself shifted fine. if you need it let me know. i can pull the governor out and send it to you, Quote Link to comment Share on other sites More sharing options...
[HTi]Johnson Posted August 12, 2004 Share Posted August 12, 2004 I have a 3AT with the same problem. Do you have a tranny fluid leak? Check your bolts and seals. My problem was solved by tightening the govenor housing bolts down. Quote Link to comment Share on other sites More sharing options...
vodoobrat Posted August 13, 2004 Author Share Posted August 13, 2004 I will be off this weekend and look into everything you guys are saying. Once again thanks for all you help....Can live without my Brat.. Quote Link to comment Share on other sites More sharing options...
