88 GL - Low with high beams??
Hi, I'd like to know if there is a way to convert the way the high beams come on. Right now when I go to high beam the low beam lights go out and I'd like to know if you can run these (and how) so that all 4 bulbs are lit when on high.
I've seen this question before but I dont' think it was ever answered.
I have..... 1988 GL 3-door w/throttle body and Overhead cam.
I'd be grateful if somebody has a light switch or something that would allow all the lights to come on.
boing
if its a gl. you have 2 filiments in each bulb. running both at the same time would really shorten the bulb life. you could use a relay or 2 to do it but I would not recomend it. just get a decent set of driving lights.
You're right.. I have a GL and it only has single lights but dual elements.
Ok. Thanks a bunch.. I can add some fog lights and I'll be good to go.
boing
