brake light and battery light coming on and off together randomly
 ive been trying to figure this one out for a couple months now. battery and brake light come on and go out together intermittently sometimes stay on for a bit before going out. has brand new alternator and brand new battery when the lights come on it is still charging at 14 volts. have taken engine grounds apart and cleaned all grounds on block took grounds off firewall and cleaned those did the ground next to the battery to the body what els can cause these lights to come on and go out together? its a 2004 outback
Edited by sirtokesalot
Was this happening before the alternator replacement?
define "brand new alternator"....OEM? Reputable aftermarket? Parts store cheapy?
Those lights are controlled by the alternator, supposed to indicate charging failure. If the lights are on and alternator is still charging, I think it would have to be a faulty alternator.
the car had a reman one when we got it we tried a used one from a car i know it worked on first then bought another one from part store.
The brake indicator is also connected to the alternator.  If it's going off and you're sure it's not the fluid/parking switches, the alternator is grounding itself.  Either it's bad or there's a short somewhere.
