Back in a GL
When you say “centre seal” do you mean on the sundial?
The seal is fitted from behind the sundial, so once it’s removed you knock it out towards the direction of the diff (orientation when the sundial is fitted).
When you fit the new seal sure you have the correct unit to put in as they are directional. Also have a new large O ring on hand to install too.
When you remove the sundial from the gearbox, mark where it’s currently located across the dial and the gearbox case, count the number of turns until the dial is free from the threads, also a good idea to mark where this point is so you’re not potentially counting a turn that’s not engaged on the thread.
Cheers
Bennie
  • Replies 113
  • Views 34.2k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • bushytails
    bushytails
    I should add, it's just my *theory* that not having a reservoir makes them crack.  I've had a lot of problems with them cracking, and here's what I decided: With no reservoir, the radiator always
  • From what I can see, that car looks surprisingly solid. Nice find!
Posted Images
Thanks Bennie,
                    Yes, that's what I'm doing. I have the o-rings as well and was able to get them new from the dealer. All I had to go on was this diagram
You’ll be right. Do one side at a time so you have a reference point for the removed sundial. If the dial becomes hard to turn about two notches past your original start mark, back it off so the marks line up. Can’t go wrong doing it this way!
Cheers
Bennie
I need to split a transmission soon, and I'll be replacing all the seals while I'm at it...  will need to figure out how to set the gears, not just mark the positions.  yay.
Changed the axle seal yesterday on the driver side. Now that I know how to do it, I could definitely do it again. I think having a shop press would making it easier in the future. I do have a Harbor Freight gift card burning a hole in my pocket. You can see the damage on the seal here. Fixed a flashing issue on the turn signals too. Someone stuck too small of a bulb in it. Took it for the longest drive it's had since I got it. Tried to give her some beans to get any junk ran through the carb. 806970020
Adding this for anyone else:
CV axle seals/LHD
Left/driver side is 806727180
Right/Passenger side is: 806727170
2 o-rings are 806970020
 Not sure why someone stuck this kind of bolt in the pinch area of the hub but luckily I had a spare:
Edited by Durania
That temperature gauge is *way* too high.  Address that promptly or you'll be getting to do head gaskets very soon.  At highway speeds the needle should be at the lower black line, and it should never get to the second black line.
That’s where the thermo fans kick in!
My brumby with that dashboard conversion (we never got them in the brat/brumby from factory like you guys in the states did) does the exact same thing when there’s not enough airflow through the radiator - typically when in traffic.
Unless you were pulling highway speeds I wouldn’t stress about it, particularly if it came back down to normal op temp just above the first black line.
Cheers
Bennie
I'm not familiar with the older gens. Does each line indicate something? Like first line is where the thermostat opens, second line is "high normal op temperature", 3rd is "dancing with danger" and 4th is really not good?
I've never opened an older gen FSM or owners manual, let alone seen an older gen in the flesh other than a BRAT at a car show once.
Are the dash readouts known for any inaccuracies such as the 3rd gen oil pressure gauges being quite vague?
I, personally, would not worry about the temp gauge. To me, that’s where I would want it to be, about the middle. I have never owned an EA81, but my ‘04 Nissan, my daughter’s ‘02 Outback and my wife’s ‘17 Legacy, all run in the middle.
I noticed that as well when I was driving it. I do know that I have a seeping radiator and trying to get a plan in action to either get it repaired or find a replacement. I did order an OEM thermostat this morning because I know how finicky the EA81 can be about aftermarket thermostats and I have no clue what's in it. The good news is the fan does run, unlike the others that I had that ran the fan all the time. My brat with an OE thermostat usually sat around this line that I have marked and I watched it constantly. I am also going to replace the radiator cap. Are the Stant ones okay? I asked my dealer and I can't get an OE one anymore.
They're going 65mph in the photo...  at that speed, it should be firmly at the bottom line, where the thermostat opens.
EA81s aren't picky about thermostats, since they're on top like most older vehicles - it's the newer EJ motors that have them on the bottom that are super picky.
My first guess would be a clogged radiator.
Where on your temperature gauge does the thermostat open?  From a cold engine, keep feeling the outlet side.  It'll be cold and then suddenly hot when the thermostat opens.  Then keep watching the gauge, and also note where the electric fan kicks on.  These are your reference points for where the gauge should read.  On level highway it should be at the point the thermostat just opens, and it should never exceed the point where the fans kick on, at any speed.
Edited by bushytails
Typo
That was the first real drive I've done in it since getting the blower going and I did notice I had good heat at the feet so at least it's flowing through the heater core. I'm going to get a plan of action with this radiator since it's currently dripping and I'm going to be changing the lower hose that's been roadside-repaired with a union piece.
  • 2 weeks later...
Huge thanks to @2brat82 for shipping me a set of rear hatch struts so that I could use the brackets off of them to complete the hatch replacements. 1000013352.jpeg.7b7e67c1e4bdded0f113dc561b2922bc.jpeg
Had a few minutes last night to piddle so I got started removing the radiator and hoses. Didn't get the thermostat out but I hope to sometime this week. Someone used a piece of PVC to merge the busted lower hose together at some point and looked to be slightly kinked. And not in a good kind of kink either.
111725.jpeg.52f72169fc1b6d29a2fb1038a7dd28ff.jpeg111723.jpeg.074767df6dff341d079b8e5694906380.jpeg
That radiator looks due for replacement.
P.S. The little powerstack battery works really well in that ratchet.
Yeah, that Dewalt ratchet was a birthday gift to myself and that thing is super handy. Love that you can swap between 3/8 and 1/2 drive on it too.
Wrapped up the cooling system project this weekend. I ended up going with this radiator: https://www.amazon.com/dp/B0DK323PVN. The fitment of it was good, not excellent, but good. I had to enlarge some holes at the bottom of the fan just slightly so I could get the bolts to line up with it. While I was in there, I replaced both hoses and installed an OEM thermostat and gasket. The real snafu was after I had pulled a vacuum on the system and got fluid in it to install the cap, only to find out the cap that I had ordered for my 84 was way smaller than this radiator could use. I did some research on here and found a GD post here that stated I needed the 82's radiator cap.
Found an 82 cap locally and drove it up the road during a rain storm yesterday. I did notice the windshield seal is leaking so gotta get a plan on that, not that I'm going to be driving it much on rainy days anyway but we get quite a bit of rain here in the fall months. After the drive, I noticed my brand new Continental belt had some fraying on the sides of it. I did notice my alternator was quite loud and had planned on eventually replacing it. I threw on a spare that I had that came with the wagon and it was totally dead with nothing on the volt meter. Ordered one from Rockauto this morning.
It'd be interesting to see the temp gauge at 65 MPH versus the last time you drove it. That radiator looks kinda bad, but I took one out of my car that was worse, albeit it was one of the later plastic tank ones. The cooling fins were literally falling out of it. I had a brass radiator welded/repaired like yours is after a wreck in a different vehicle, and that thing lasted nearly 40 years! Some of those guys do great work.
 Alternator changed Friday evening and had a muffler put on by a local mom-n-pop shop this morning. Next on the list is a water pump. I noticed my belt was fraying after that quick drive up the road last week. I am confident I've got the water pump for non-AC GLs and it's slightly out of alignment. 1000013727.jpeg.986c28dd4bb9a886fefdcee98058cebb.jpeg
  • 2 weeks later...
Replaced the water pump with the GMB 1601030 since it listed it being shorter. I'm not 100% but I really think I had the longer GMB pump, hard to tell from the level picture.
Yes, those are monster hose clamps.
I thought all EA81 water pumps were the same and that the height difference was in the EA82 water pumps.
That's what I thought too until I saw that they offered two different sizes on RockAuto and then found this thread:
^ they’re talking about the EA82. The 1990 and 1991 Leone ran the EA82, they started in 1984 which was the crossover year from the EA81 models to the EA&2 models (and maybe some left overs in 1985).
The EA81 continued in the Brumby/BRAT until production of those models ceased.
Edited by el_freddo
Spelling
