Dwayne Oxford Posted 19 hours ago Share Posted 19 hours ago Just learned Subaru has obsoleted them, the aftermarket boots don't last. Anybody able to help? Link to comment Share on other sites More sharing options...
scoobydube Posted 5 hours ago Share Posted 5 hours ago When you buy the entire CV axial, the boots will last for a couple hundred thousand miles. What the subaru mechanics like to do it coat them with a fluid that causes them to disintegrate in about 3 weeks, so you will be back in 4 weeks to have even more work done. It is generally a waste of time to put new boots on a high mileage CV axial. Replace the entire assembly. 1 Link to comment Share on other sites More sharing options...
el_freddo Posted 4 hours ago Share Posted 4 hours ago I’d argue that new boots on an old OEM cv shaft assembly is well worth the effort if it’s not left to grind along with loads of road grime, water and dirt in there. A mate of mine swears by stretchy boots. I saw one (now a meme somewhere) that wrapped the boot around the shaft a number of times when the gizzards of the CV joint let go for whatever reason. The CV joint was rebuilt on the side of the road and the boot reused! I’ve used various aftermarket boots with good success. I next time I’ll be trying these stretchy boots. Cheers Bennie 1 Link to comment Share on other sites More sharing options...
SuspiciousPizza Posted 57 minutes ago Share Posted 57 minutes ago Try looking for an EMPI 86-1098-D. See if the boot shape matches. :] 1 Link to comment Share on other sites More sharing options...
