SquigSprinter Posted September 21 Share Posted September 21 Hey folks For those of you who have gone down the path of putting a divorced transfer case and using a rear diff (plus fabrication) to serve as a front diff, how well do the diffs and cv axles hold up to the additional low range gearing? For context this is using the newer VA type 2 r160 diffs found in the Ascents and Outback Wilderness (with the 4.44 final drive) and newer style CV axles that don't have the stub out for the inner CV assembly. This would be getting mated to a Subaru dual range with 1.44 reduction Mostly curious if something like the Suzuki tcase with the extra low range gearing will be too low for the rest of drivetrain. If you've done this mod before, how well did the rest of the drivetrain hold up? Link to comment Share on other sites More sharing options...
el_freddo Posted 1 hour ago Share Posted 1 hour ago I have not done this and those that did this years ago are most likely long gone from the forum. One of the biggest factors is your driving style and mechanical sympathy. With a dual range gearbox and the dual range divorced transfer case and the addition of 4.44:1 diffs, you could run larger tyres and crawl really slowly - best of both worlds. What vehicle are you putting all of this into? If a vehicle with an AWD, you’ll need to weld the centre diff. Being a 1.44:1 low range it’s either an MY chassis or the sf forester (but I didn’t think you guys got the dual range gearbox from factory in the states). Link to comment Share on other sites More sharing options...
