Replaced evaporative canister solenoid, catalytic converter code off now too
From what I'd heard, the evap. canister does not affect performance.  However, I replaced it on my 2002 Forester as I've been living with the codes for a long time, but needed to pass emissions here in CT.  Now both the evap. canister code and the catalytic converter code are off.  Are these affecting each other? I fixed one and both codes came off.  I got it on Amazon for around $30.
Edited by ThosL
It's been off.  Replacing the solenoid is a little difficult if you don't have a lift.  I had snagged one off a junkyard Subaru, it worked for a little while then probably shorted out.  It's just not worth trying junkyard parts unless they've been checked.  I got an ignition coil off a junkyard vehicle a while ago and it was worse than useless.
Larry, it’s tough around here. Too many lawyers. Most places don’t let you walk around anymore.
You guys enjoy what you have !
Tom, there’s always F&S. If it’s older than 20 years just talk with one of the guys in the Roxbury yard like Jeff.
Not sure about Johnny’s in Thomaston, i think it’s changed hands but that was another good yard where he would let you walk around.
Which place do you go to? LaJoie’s?
