MilesFox Posted August 13, 2004 Share Posted August 13, 2004 who was it that knows what size toll was required to disassemble the rear differentiol, the "inverted torx socket". whats the part number and where do we get it. search was futile, it was posted not too long ago Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 13, 2004 Share Posted August 13, 2004 E-10 torx. Must be 1/4" drive. You can get it from Snap-On, Matco, etc. GD Quote Link to comment Share on other sites More sharing options...
myossfeece Posted August 13, 2004 Share Posted August 13, 2004 yeah That was wha I needed to know. I have a 3.7lsd and a 3.9 rear end, both with a broken axle stub. I am hoping to part them both and come up with a 3.9lsd with two good axle stubs on it. thanks gd Quote Link to comment Share on other sites More sharing options...
baccaruda Posted August 13, 2004 Share Posted August 13, 2004 get the 1/4" drive version if possible as it's a pretty tight fit in the axle stub. Quote Link to comment Share on other sites More sharing options...
Qman Posted August 13, 2004 Share Posted August 13, 2004 1/4" drive deep socket. E10 as stated above. Quote Link to comment Share on other sites More sharing options...
MilesFox Posted August 13, 2004 Author Share Posted August 13, 2004 thanx q. we found the article in the usrm, but the computer wont print! anyway we read that you will need to use 3.7 axle shafts to match the ring gear. we have the lsd and the 3.9, both with one torched stub each. but we DO have an open 3.7 that we can use for the axle shafts, a matching pair Quote Link to comment Share on other sites More sharing options...
Qman Posted August 13, 2004 Share Posted August 13, 2004 Stub axle shafts do not matter in the rear diff. They are all the same. All you need to do is remove the center section from the housing. Keeping the components from the 3.90 gear together. Grind the housing like the LSD housing. You see the difference once the cover is off. Change the ring gear to the LSD and reinstall in the 3.90 case. Done! Quote Link to comment Share on other sites More sharing options...
MilesFox Posted August 14, 2004 Author Share Posted August 14, 2004 thanx! Quote Link to comment Share on other sites More sharing options...
