aa8jz Posted August 18, 2004 Share Posted August 18, 2004 Only 2nd or third time I have pulled an engine on a Soob. I didn't remove four bolts from torque converter. Center shaft slide out of tranny about 4-5 inches before I could do anything about it. Didn't hear anything falling out of place. Slid back in ok but being a huge pessimist I am thinking the worst. Any insight? rick w mi Quote Link to comment Share on other sites More sharing options...
Craven Posted August 18, 2004 Share Posted August 18, 2004 Only 2nd or third time I have pulled an engine on a Soob.I didn't remove four bolts from torque converter. Center shaft slide out of tranny about 4-5 inches before I could do anything about it. Didn't hear anything falling out of place. Slid back in ok but being a huge pessimist I am thinking the worst. Any insight? rick w mi Should be fine, as long as you didn't put a bend in the shaft. If the Subaru auto is like most US automatics, you can pull the shaft all the way out, and inspect it. Then slide it back in.Craven Quote Link to comment Share on other sites More sharing options...
calebz Posted August 18, 2004 Share Posted August 18, 2004 Yup.. what he said ^^ Just did the same thing a couple weeks ago.. 1500 miles later, no problems Quote Link to comment Share on other sites More sharing options...
Turbone Posted August 18, 2004 Share Posted August 18, 2004 Make sure you remove the TC from the flywheel. Install the TC back on the tranny, turning it untill you feel the keyway slip in the shaft. Then your ok to put the tranny back on the engine. Failure to do this will result in a ruined tranny, and reattach the TC to the flywheel. Believe me, I had to learn the hard way Quote Link to comment Share on other sites More sharing options...
calebz Posted August 18, 2004 Share Posted August 18, 2004 I've done it the wrong way a number of times then. On chevies, fords, chryslers and subarus... Haven't killed one yet.. Guess I'm just tempting fate. BTW, to avoid confusion, Its Flexplate.. Not flywheel... No flywheel on an auto Quote Link to comment Share on other sites More sharing options...
aa8jz Posted August 19, 2004 Author Share Posted August 19, 2004 tnx for all the data folks. this is a great site. would be lost without it. appreciate your time. will pay more attention next time a motor comes out.. rick Quote Link to comment Share on other sites More sharing options...
