September 9, 200421 yr How offten do U adjust the valves on a solid lifter EA81? And what do U set them too?
September 9, 200421 yr I adjust them when the valve cover gaskets need replacing follow instruncions underhood for "gap" start at 1, tdc comp, then 2, 180* apart , then 3 should be back to the 0* mark, then 4, 180* apart there is a mark at 180* on the flywheel, and a notch or a hole in the crankshaft pulley at 0* and 180*
October 20, 200421 yr could some one enlighten me a little more on this process? I have a solid lifter and it sound like a typewriter badddd..
