tools required to split the block?
Besides standard sockets, wrenches, the wrist pin puller, and some hex socket pieces... what else?
You'll need a pair of long needle-nosed pliers to remove the spring clips that hold the wrist pins in the pistons.
Just make sure you get ALL the bolts out first! Both times I've had a block apart, I forgot one bolt, smacked the thing forever, then checked to see if there were still some bolts in there, took the bolt out, and it came apart nearly by hand.
