Myxalplyx Posted October 17, 2004 Share Posted October 17, 2004 Sorry if this sounds like a stupid question but I can not find my horn on my 1988 RX. I went to change it out today but couldn't locate it. I believe there is supposed to be a 'high' and 'low' horn (at least it looks this way in the FSM). I looked in the engine bay and couldn't find it. I expected it to be in front or near the radiator. The FSM doesn't show its location (or their locations). Can anyone help me? Thanks! Quote Link to comment Share on other sites More sharing options...
bajavwnsoobnut Posted October 17, 2004 Share Posted October 17, 2004 it's behind the bumper IIRC Quote Link to comment Share on other sites More sharing options...
DrKrazy Posted October 17, 2004 Share Posted October 17, 2004 Haven't looked on my RX yet but on the 88 DL it's under/behind the front bumper on the driver's side (noticed it when I changed the bumper). Which prob means it's a pain in the rump roast to get to on the RX. Quote Link to comment Share on other sites More sharing options...
Skip Posted October 17, 2004 Share Posted October 17, 2004 Kevin, there are two horns behind the bumper ends. the easiest way to get to them is remove the headlamp assm. (four 10 mm nuts behind the core support, one sheet metal screw on top for the side marker lamp) pass side is easiest if you just want to get to the wiring in order to add an aux horn. congrats on the RX by the way - you're welcome Quote Link to comment Share on other sites More sharing options...
Myxalplyx Posted October 18, 2004 Author Share Posted October 18, 2004 Kevin, there are two horns behind the bumper ends. the easiest way to get to them is remove the headlamp assm. (four 10 mm nuts behind the core support, one sheet metal screw on top for the side marker lamp) pass side is easiest if you just want to get to the wiring in order to add an aux horn. congrats on the RX by the way - you're welcome Thank you Skip! This is exactly the info I needed. And thanks for the congrats! Quote Link to comment Share on other sites More sharing options...
WJM Posted October 18, 2004 Share Posted October 18, 2004 what skip said. HEY SKIPPER!!! Aint seen you on in forever! Quote Link to comment Share on other sites More sharing options...
eddie6937 Posted March 22, 2005 Share Posted March 22, 2005 Hi there, Is it easy to find. My horn is making a buzzing sound when I press it. What exactly does it look like behind the headlight. All I see is a bunch of wiring. Eddie Kevin, there are two horns behind the bumper ends. the easiest way to get to them is remove the headlamp assm. (four 10 mm nuts behind the core support, one sheet metal screw on top for the side marker lamp) pass side is easiest if you just want to get to the wiring in order to add an aux horn. congrats on the RX by the way - you're welcome Quote Link to comment Share on other sites More sharing options...
bajavwnsoobnut Posted March 22, 2005 Share Posted March 22, 2005 what year is your subie? Quote Link to comment Share on other sites More sharing options...
eddie6937 Posted March 22, 2005 Share Posted March 22, 2005 1988 Subaru Wagon- DL what year is your subie? Quote Link to comment Share on other sites More sharing options...
Skip Posted March 22, 2005 Share Posted March 22, 2005 Eddie, please take a moment and read the description more carefully. They are round and somewhat flat. You must take the headlamp assembly out to see it. Quote Link to comment Share on other sites More sharing options...
