douglasbdavis Posted October 18, 2004 Share Posted October 18, 2004 Hello, I'm getting frustrated and hope someone has ideas. Last night most of the electrical system on my 94 loyale wagon failed. Nothing works except for interior light, key chime, door locks, hazard flashers, parking lights (only when switch on steering column turned on) and horn. I've got no headlights, ignition, starter, dash lights, fuel pump, dash buttons etc. I've checked everything I can think of- all fuses,fusable links, battery and terminals, grounds, wire plugs-- can't find the problem. Any ideas? I'm a pretty good amatuear mechanic and I'm stumped. Thanks in advance Doug Davis Link to comment Share on other sites More sharing options...
chef_tim Posted October 18, 2004 Share Posted October 18, 2004 Check the small lead on the starter, the one that is a clip. I know they do funky things when unplugged/dirty beyond contact. Tim Link to comment Share on other sites More sharing options...
pm128 Posted October 18, 2004 Share Posted October 18, 2004 Just a guess, what about the ignition tumbler (where the key goes).. just a thought.. Link to comment Share on other sites More sharing options...
subiemech85 Posted October 18, 2004 Share Posted October 18, 2004 how did you check the fusible links? Link to comment Share on other sites More sharing options...
douglasbdavis Posted October 18, 2004 Author Share Posted October 18, 2004 Links were hot on both sides. I cleaned the clipped on lead to the starter no effect. Should that wire be hot? It is not. I'm wondering if that is a clue. Thanks Doug how did you check the fusible links? Link to comment Share on other sites More sharing options...
canajun2eh Posted October 18, 2004 Share Posted October 18, 2004 That clip-on lead on the starter isn't supposed to be hot. It's the "start" lead for the starter solenoid. Your symptoms sound as if the ignition switch has failed. Link to comment Share on other sites More sharing options...
douglasbdavis Posted October 18, 2004 Author Share Posted October 18, 2004 Yea, I think you are right. Any trick way to check that without taking the steering column apart? I'm wondering if there is someplace I can jump to bypass the switch that is easier to get to. Thanks, Doug That clip-on lead on the starter isn't supposed to be hot. It's the "start" lead for the starter solenoid. Your symptoms sound as if the ignition switch has failed. Link to comment Share on other sites More sharing options...
douglasbdavis Posted October 18, 2004 Author Share Posted October 18, 2004 Problem solved. The connector plug between wire harness and ignition switch was lose. Maybe I dislogded it with my foot while driving. Thanks all for the help, Doug Yea, I think you are right. Any trick way to check that without taking the steering column apart? I'm wondering if there is someplace I can jump to bypass the switch that is easier to get to. Thanks, Doug Link to comment Share on other sites More sharing options...
DrKrazy Posted October 18, 2004 Share Posted October 18, 2004 Gotta love it when it's the easier and cheaper fixes! Link to comment Share on other sites More sharing options...
