mschafe Posted October 20, 2004 Share Posted October 20, 2004 I finally got my 85 GL running after 6 months of sitting (needed a distributor). It runs great now, but is leaking coolent from somewhere. Its pooling on the top left of the engine when the car heats up, and then drips down to the ground. Its not a small leak, its coming out pretty good. The hose connections look fine, and the car has a brand new radiator and water pump installed. I just can't see where it is coming from. If someone can help, I need to get this car fixed so i can put it up for sale asap. Thanks, Matt Link to comment Share on other sites More sharing options...
Snowman Posted October 20, 2004 Share Posted October 20, 2004 I assume you are talking about left as viewed from the front of the car. Thermostat housing gasket, intake manifold gasket, the little hoses that connect to the intake manifold, and coolant temperature sensor are all possible places. If it's left as you sit in the drivers seat, then thermostat housing and coolant temp sensor can pretty much be ruled out. Since it is a sizable leak, I would just clean everything off really well, start the car, and see if you can see where its coming from. It should be relatively evident. Best of luck! Link to comment Share on other sites More sharing options...
86subaru Posted October 20, 2004 Share Posted October 20, 2004 check the heater hoses , because they can leak on the bottom of the hoses and can be hard to see , right below the spare tire, 2 hoses Link to comment Share on other sites More sharing options...
tailgatewagon Posted October 20, 2004 Share Posted October 20, 2004 there is a small hose that gos to the block from the front of the intake rightunder the carb. or some where around there look for them most of the time its just a pin hole and only leaks once the car is hot... look with a light and take your time you will find it good luck. Link to comment Share on other sites More sharing options...
mschafe Posted October 20, 2004 Author Share Posted October 20, 2004 Yes, its looking from the front of the car. I suspect its the thermostat housing, as thats the only thing that hasn't been replaced, and the pool of coolent is pretty much right under it. ALTHOUGH, I could NOT see it dripping while the car was running, I just noticed a pool of coolent on the ground after a while. Very strange. Link to comment Share on other sites More sharing options...
Snowman Posted October 21, 2004 Share Posted October 21, 2004 I'd just throw on a new thermostat housing gasket. They're cheap and pretty quick/easy to replace. You might pull the temp sensor and put some sealant on while you're at it. Those don't leak very often, but if it was my car, it would make me feel better;) . Edit: Also, I've had good luck putting the factory subaru gasket on dry (no sealant), but if you want to use any kind of sealant, use Permatex Aviation Gasket Maker. It does a great job sealing and is really easy to clean off if you have to take it apart again for any reason. Link to comment Share on other sites More sharing options...
cowboystrait Posted November 29, 2005 Share Posted November 29, 2005 check all little hoses heatercore hoes too Link to comment Share on other sites More sharing options...
