October 29, 200421 yr Hello everibody, I have a 86 4wd leone and my problem is:-every time i start the lights my tachometer is going crazy(i meen that is indicating more RPM ) also when i start the engine in the morning I have the same problem. Thank you )))
October 29, 200421 yr from the small abount of info i have, id say alternator. does the voltage meter do anything wierd.
October 30, 200421 yr i have never dealt with this problem personally but have seen other posts where the cause of tachometer problem is a badly grounded alternator i.e. the earth is not a solid electrical connection. do a search and you should find a way to correct this:banana:
