torque spec ?
With the car jacked up, make sure the axle is fully seated in the bearings, place the rotor on, cone washer, washer, nut. Tighten the big nut to 145#, if you can't get 145# in the air, lower the car for the last few pounds but make sure everything is properly seated first. If the cotter pin does not line up, tighten the nut a bit more until it does.
