1981 suspension adjustment for rear and front end.
A DOG
If you have a wagon, lift your rear seat up. Then you'll see a rubber cap that you remove. After you remove that cap, you'll find a 17mm nut that you can turn. This adjusts your rear torsion bar.
For the front, there are 2 bolts on each Strut. Just under your spring. YOu can use a 19mm wrench to adjust them. Its a pain in the rump roast since those bolts probably see more dirt and road grime than anyother peice of your car.
You wont get much more than 1.5" out of the adjustment.
-Brian
-Brian
Clarification, the strut nuts are 21mm and the rear torsion bar bolt is 19mm.
