December 26, 200421 yr I was doing some work on my GL the other day and discovered that the upper bracket for the radiator had come loose from the tank on one side. I've done this repair before but I haven't read too much about it on the USMB or USRM. So I decited to do a little write-up and share some knowlege. It is a PDF file so you will need acrobat to read it. I think this covers everything. If the Moderators wish to add to the USRM please copy the file to a different server. My space is limited with comcast. http://home.comcast.net/~c.moe/radiator_repair.pdf.
December 26, 200421 yr cool. I grabbed the file, and moved it to the USRM, and added the article out there under the USRM Link...
