archemitis Posted December 26, 2004 Share Posted December 26, 2004 im wondering if it matters which rocker i hook my throttle cable up to on an er27. one is for throttle, and one is for the damn cruise, which im not using. does it matter, is it the one closer to the driver side, or passenger side, that is the intended throttle? Quote Link to comment Share on other sites More sharing options...
TomRhere Posted December 26, 2004 Share Posted December 26, 2004 Never gave that lil tid-bit much thought. Guess I'll have to look into it myself tomorrow, while I finish up the '84. Hmmmmmmmmmm.............. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted December 27, 2004 Share Posted December 27, 2004 i think i'd use the one that the gas pedal is connected to. i think one will only pull back if the other is beyond the *rest* position, so i wouldn't use that one. the other will pull independently i believe. i'm in ohio and drove my truck otherwise i'm tempted to go inspect for you. whichever one moves independently is the one i'd use. it's only moving the throttle plate (and the TPS) so as long as you choose the rocker that has full independent motion you'll be golden. Quote Link to comment Share on other sites More sharing options...
