January 17, 200521 yr First, let me say that I am a total repair novice, but I am on a mission to learn about car repair. I have owned an 84 GL (OHC) and have the HOW TO KEEP YOUR SUBARU ALIVE book by Larry Owens. The book only covers models through 1988 with its nifty little diagrams. It is the first book I have seen that gives me the little confidence to branch out into repairs. As I do so, I realize that my car may be out of service for a few days from time to time so I am looking for a second car, one that I can use the same book to work on. MY QUESTION IS THIS: Are there any real differences between the Loyal an GL for repair purposes? Can I get by with this book on a Loyal, in the same way an 85 GL is the same as an 88 GL?
January 17, 200521 yr about the only diffrence is loyale will all be fuel ingected and alot of gl wheren't. are you sure you have an 84 with OHC i do believe that was not used till 85. i could be wrong though it has happened before
January 17, 200521 yr GL has more cool stuff to keep you busy :cool: 88 GL (and Loyale) will have the fuel injected 1.8L engine. 85 GL should have a carb on it. That's going to be the biggest difference in engines.
January 17, 200521 yr The book will be fine, if you do a search you can find a much more in depth review of the differences
