January 28, 200521 yr anyone know where i can get an O2 sensor for my '91 Loyale. i'm just looking for the best price.
January 28, 200521 yr Hey buddy Check out https://www.rockauto.com/applet3.html for any part you might need the keep you SUBARU running. This is an awsome site for parts! I found about 10 O2 sensors for your car they are anywhere from $8 - $155. Just go through the searching process. Good luck Scott Schinsky 2005 Legacy 2.5GT 1984 Brat
January 28, 200521 yr Jef Any universal single wire 02 sensor will work in your car The factory unit was made by Bosch Napa has a universal single wire Bosch for less than 20 USD
January 28, 200521 yr JefAny universal single wire 02 sensor will work in your car The factory unit was made by Bosch Napa has a universal single wire Bosch for less than 20 USD just make sure if you use a cut and splice universal O2 that you dont get the ground shielding wire crimped together with the signal wire. (its all in one wire) when I got my old RX thats how it came to me. O2 no workie that way.
