March 11, 200521 yr the way i had my idle set it was idleing about 750 rpm's after i finally decided to get around to replaceing the fuel filter it dropped all the way down to 450 to 500 rpm's not that im complaining but is this normal? i noticed on the hood info sticker it said the idle was supposed to be 700 rpm's now if i can get rid of this damn miss i got it will be running real smooth
March 12, 200521 yr Wow, that's kinda wierd, don't know about that, but I did have a pesky miss I tracked down to "carbon tracks" in the distributor cap, and then faulty plug wires, which appeared fine until I opened the hood when it was dark, and saw the lightning show.
March 12, 200521 yr Author yeah i didnt know what to think either i would have firgured better fuel flow would make the idle higher not lower,, but i got 1 of those carbs with no air, fuel setting screw, so maybe it electronically reset the fuel flow or something and brought it down. i had changed the whole fireing system, cap, rotor, plugs and wires, i have a feeling that my miss is because the rear plug hole on the dr side was crossthreaded and i was only able to get the plug in about 90% of the way. need to dig around for my tap and die set and rethread the hole im thinking it will probably get rid of that miss.
March 20, 200521 yr could he have installed the fuel filter backwards? they usually have "FLOW" with a direction on em, probably there for a reason
