NoahDL88 Posted March 13, 2005 Share Posted March 13, 2005 So I was looking at the FSM and the output shafts are clearly different for the two transmisisons, but the number of teeth on the end are the same, 10 its the ring gear thats different, 37 or 39, so the theory is that they might be the same? probably not though, anyone ever take a look at those? Quote Link to comment Share on other sites More sharing options...
mudrat79 Posted March 13, 2005 Share Posted March 13, 2005 The 10 teeth on the pinion although 10 are slightly different in size.... Think 10 teeth meshing to 37 versus 39.... So yes they are different unfortunately..... P.s. I have your Goodies sitting here in a Box.... John Quote Link to comment Share on other sites More sharing options...
Dr. RX Posted March 13, 2005 Share Posted March 13, 2005 So the pinion gear of the rear diff has ten teeth and it meshes with either a 37 or 39 tooth ring rear, but the ten tooth pinion gears in the trannies are different enough that a 39 tooth ring gear won't mesh with the ten tooth pinion from a turbo tranny? Well I have change many rear diffs to know that that works, but i have never tried the tranny ring gear, I guess because I consider it such a hassle to take apart. So Noah, what are you after, the gear ratios of the RX tranny in a N/A tranny? Quote Link to comment Share on other sites More sharing options...
NoahDL88 Posted March 14, 2005 Author Share Posted March 14, 2005 Basically what i want to do is take all the better parts of both trannys and make an AWD with the 1.59 low range and the 3.9 final drive. cause, no offence Austin, but the water wagon sucks to accelerate, too much power with the 2.2 so all wheel drive would solve that, and with the diff lock i can still off road. According to our more adventurous Aussie bretheren, the low range will swap, but that still leaves the 3.7 which as we all know the 3.9 is bad enough as is Quote Link to comment Share on other sites More sharing options...
Dr. RX Posted March 14, 2005 Share Posted March 14, 2005 Basically what i want to do is take all the better parts of both trannys and make an AWD with the 1.59 low range and the 3.9 final drive. cause, no offence Austin, but the water wagon sucks to accelerate, too much power with the 2.2 so all wheel drive would solve that, and with the diff lock i can still off road. According to our more adventurous Aussie bretheren, the low range will swap, but that still leaves the 3.7 which as we all know the 3.9 is bad enough as is This is the reason why I would have stayed with the EJ series tranny. True it doesn't have the dual range (I'm still working on that), but it more then makes up for that with teh better torque. Quote Link to comment Share on other sites More sharing options...
