fgug Posted March 28, 2005 Share Posted March 28, 2005 Hi, I can get a set of puegeot alloy mags, 15 inch wheels.. can I put these on a loyale without a lift?.. do I need any mods? what sized tire will be the best advised? thanks everyone. FGUG Quote Link to comment Share on other sites More sharing options...
Knichol Posted March 28, 2005 Share Posted March 28, 2005 I have a 91 loyale with the 390mm puegeot wheels with 190 65 tires with no lift, I had to bend in the front corner of the front fender just a bit. Still looks fine. Quote Link to comment Share on other sites More sharing options...
MorganM Posted March 28, 2005 Share Posted March 28, 2005 Make sure the rims are truely 4x140mm (bout 5.5") bolt pattern. Not All Pug rims fit Also try to avoid the metric ones mentioned above. Tires for those metric sized rims are expensive! Wether or not they fit really depends on the tire size you go with. What tires you go with depends on what you will be using your Subaru for; and what you can afford of course. Quote Link to comment Share on other sites More sharing options...
Knichol Posted March 29, 2005 Share Posted March 29, 2005 Yeah definitly dont get the 390mm wheels, I got a steal of a deal, and thats why I am running them. Quote Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted March 29, 2005 Share Posted March 29, 2005 The 15's will fit just fine w/out a lift. To keep your speedo correct i would advise getting a set of 195/50R15's or 205/50R15's. My RX has 195/50's on it, and they look great. No rubbing, no modifications, straight bolt on. Do make sure you get the peugeot lug nuts as well, it is vital that you use those with the 15" alloys you are about to get. -Brian Quote Link to comment Share on other sites More sharing options...
