April 5, 200520 yr Short of replacing worn out bushings or bending something, I'm pretty sure it's fixed and non-adjustable.
April 5, 200520 yr same here - check bushings/bearings for free play/noise - actually, I need to do my rear suspension bushings damaged/worn out rear struts can also do weird stuff to the rear alignment - you can adjust preload on the rear struts (at least on 4WD models) but that is it
April 5, 200520 yr You can tweak it a bit to get it into factory spec, theres the info from the '89 FSM. Gary
April 6, 200520 yr My car has had the inners slotted and eccentric bolts fitted to make it fully adjustable. Cost me a packet, I am not happy about that part but at least the cars fixed...
