April 12, 200521 yr Ok Ok I gotta know, it is really not a big deal to do a lift? and is the ride better, and why is the back end up like a stink bug????? Hey can you change out the jugs on the motor like a vw for a bit more power???? Hey my stock carb sucks, what's better... Just a day in Eugene, Oregon weather to sell or build a Subaru I'm just on the fence....but this Ultimate Subaru place does make it pretty cool. Thanks guys Derek Wolf
April 12, 200521 yr Keep it, lift it. If its a 4wd, you can adjust the rear ride hieght: Under the rear seat in the middle theres a rubber bung - take it out, then turn the bolt under it to adjust rear suspension.
April 12, 200521 yr Author Ross thanks for the heads up on the lowering of the back, man my ride looked like a stink bug going down the road, even the headlights were pointing down. Thanks for the information.....Derek Keep it, lift it. If its a 4wd, you can adjust the rear ride hieght: Under the rear seat in the middle theres a rubber bung - take it out, then turn the bolt under it to adjust rear suspension.
April 12, 200521 yr To keep it or not is completly upto you. Do you like the vehicle? Would you rather have something else? If you keep it; then on to the lift question. Would you need a lift? Do you have the money, time, and tools to build or install a lift? Also have the money required for bigger tires and rims to go with that lift? That's my unbiased analysis of your situation at hand. This is the USMB; of course we are going to tell you to keep it and lift it from our biased, opinionated viewpoint
April 12, 200521 yr I'm not sure lifting it will improve the ride or handling. Most all old 4wd Subarus have the stink bug look. That's what makes them unique. That's what I like about them. Power is a relative term. A good running engine should get you around just fine. If the engine is running poorly a tune up seems to cure most everything that ails that engine. However, you'll never make that engine "fast". If your looking for fun vehicle that will take you most anywhere you want to go then the Subie is a good choice. My .02 Glenn 82 SubaruHummer 01 Forester
April 12, 200521 yr keep it if you want a reliable engine series.. EA81s are bomb proof. 350 bucks for a lift, 500 for tires and rims, A lil hijack, Ross - where is that rear suspensionm adjuster on a Brumby?
April 12, 200521 yr Ok Ok I gotta know, it is really not a big deal to do a lift? and is the ride better, and why is the back end up like a stink bug?????Hey can you change out the jugs on the motor like a vw for a bit more power???? Hey my stock carb sucks, what's better... Just a day in Eugene, Oregon weather to sell or build a Subaru I'm just on the fence....but this Ultimate Subaru place does make it pretty cool. Thanks guys Derek Wolf Keep it and lift it. Talk to mudrat79 about the lifts because he makes them to. I dout it would help the ride. Go with a Webber carb.
April 12, 200521 yr Author You know I call the subie ROXANNE... when she hot...she HOT...but...haha..I been looking at some of the rides on here that have been lifted and they look really cool...so yep I have the money,time,tools, and most of all I have this message board to get advice...So now can someone point me in the direction of who to buy a lift from....This is cool To keep it or not is completly upto you. Do you like the vehicle? Would you rather have something else? If you keep it; then on to the lift question. Would you need a lift? Do you have the money, time, and tools to build or install a lift? Also have the money required for bigger tires and rims to go with that lift? That's my unbiased analysis of your situation at hand. This is the USMB; of course we are going to tell you to keep it and lift it from our biased, opinionated viewpoint
April 12, 200521 yr Author I did the turn under the back seat and got a really cool look now, I was really hanging the tail up in the air before....I am ok with the power I have when I bought the car I had the engine checked out and the garage guy said I need to change the head gaskets that they are leaking....and power loss. But I have really enjoying the car...its really fun to be back into a driving project..Thanks...Derek I'm not sure lifting it will improve the ride or handling. Most all old 4wd Subarus have the stink bug look. That's what makes them unique. That's what I like about them. Power is a relative term. A good running engine should get you around just fine. If the engine is running poorly a tune up seems to cure most everything that ails that engine. However, you'll never make that engine "fast". If your looking for fun vehicle that will take you most anywhere you want to go then the Subie is a good choice. My .02 Glenn 82 SubaruHummer 01 Forester
April 12, 200521 yr You know I call the subie ROXANNE... when she hot...she HOT...but...haha..I been looking at some of the rides on here that have been lifted and they look really cool...so yep I have the money,time,tools, and most of all I have this message board to get advice...So now can someone point me in the direction of who to buy a lift from....This is cool Here are some lift kit options then! =========================== http://www.ozified.com =========================== Mudrat Design & Fabrication I can build Anything Custom 541-206-2494 =========================== http://alliedarmament.homestead.com/index.html ===========================
April 12, 200521 yr Keep it. Old Soob wagons are solid gold. Lift? Mudrat79 (contact info above) just happens to be in Eugene. He can set you up.
February 3, 200620 yr keep ur wagon make it the most urban assult subaru u have seen ,then take pics and em here:headbang: on the board
