Help car stalls
I have a 1993 sedan 4wd and is fuel injected and is an automatic. When I take off it stalls as if it had a carb and had a dead spot in it. I took off at a stop sign and it took off then stalled. The car does not stop it just drops in power then in a couple seconds it takes off. I took off at an intersection and almost got hit because of the stall. Dose anyone have a clue whats happening.
Thanks in advance !!!!!
I wouldn't overlook the normal tune up stuff, air and fuel filter, plugs wires etc. Not saying it isn't the MAF, it is good to rule the basic stuff out first. A plugged fuel filter from my experience will effect the low end performance fairly dramatically.
