May 14, 200520 yr make a notch on the side piece that has the 3 bolts to make room for the brake line, that or swpa on the ea81 brake line on the pivot part that bolts to the tube frame, you will have to drill out the holes and use the larger ea82 bolt
May 15, 200520 yr the one bolt that holds the trailing arm to the tube frame, not on the side with the 3 bolts, but the inner part wit the one bolt, drill the holes on the tube fram to use the larger ea82 bolt.
May 16, 200520 yr I think some of the advantage might be the ability to mount a rear swaybar while taking the parts needed off a turbo EA82 wagon.
May 16, 200520 yr Author I think some of the advantage might be the ability to mount a rear swaybar while taking the parts needed off a turbo EA82 wagon. Exactly!
